How To Render 1million Polygons?
i have a scene with 1 300 000 polygons (no textures).
MR is running out of memory (quad core, 3 gigs of ram) even if i set memory limit to 2500
already tried BSP, Large BSP and BSP2
how can solve this problem?
here's my scene:
http://sor.typepad.com/sor/2008/11/tst4-1.html
(memorytst-right click - save as)
If you are on a 32 bit operating system and you didn't enable the large memory address aware flag (/3GB) in your ini file then you will only beable to use about 1.5 GB
how can i enable the large memory address aware flag (/3GB) in my ini file ?
http://technet.microsoft.com/en-us/library/bb124810.aspx
thanks alot.
so 3 gig is the max for a winxp 32 right?
more like 2.5
i noticed that sometimes MR runs out of memory before even hitting the memory limit that i fixed. why is that
QUOTE(ROYTERR @ 11/27/08, 09:47 AM) [snapback]295986[/snapback]
how much was it using when it ran out?
1200 MB
QUOTE(ROYTERR @ 11/27/08, 10:42 AM) [snapback]295991[/snapback]
1200 MB
if that was before you set the /3gb flag then that sounds typical
Actually from my experience I never found much use for the memory setting unless you need to limit the amount of memory. It won't force the computer to use more than it can. If it's maxing out at 1200 then try setting the limit to 1100. But you also have to set the BSP settings so that it does not try to do more per bucket or whatever.
