I need to animate something that is very similar to the howler in harry potter:
http://www.youtube.com/watch?v=Gxw\_qaTxFsc
ie: folded up paper that is animated with some extreme motions.
Rigging it all with bones would be pretty time consuming to get the rig
and sdk’s setup and I’m not sure it will yield nice fluid deformations.
Or I could do the whole thing as blend shapes.
Or try to use nCloth somehow?
Open to any and all suggestions on how best to rig.
Thanks!
I’ve never rigged anything like it but if i was to:
I would probably have a simple joint rig in place for simple jaw movements and such. Blendshapes for subtleties like different eye shapes and paper folding. Maybe even have a lattice for widescale deformations.
Just a thought
Hmmm, interesting.
I would stay away from Ncloth unless you’re doing shot specific rigs and you want a certain type of deformation for one particular cut. I think the best way to approach this if you’re just making one rig would be a mix of bones and blendshapes. Technically, you could do the entire thing with bones or influence objects, which would essentially result in a very complex facial setup, or you could have it be entirely blendshape driven. I think if I were to tackle it, I would use mostly blendshapes with bones for added control in certain areas. Also depends on how high poly this thing is going to be (you could create a low poly proxy, rig that, then wrap the final mesh, although you would need to correct this a bit once it was done).
Either way, it would be best to setup connections and SDKs - rigging is time consuming, that’s just the nature of the beast.
