Warning: line 1: Some items cannot be moved in the 3D view.
How many times ... ?!?!? I don't want to read this anymore. Does someone know of a way to turn this off? I really get kinda pissed if I see this 200 times more... Unfortunately it can't be found in Maya scripts.
OK.. why not turn off the commandline? Because I want to see if there is really some sh!t steaming.
OK, what about evaluating empty prints after tool change? ?
Someone gotta fix to catch that problem at the root?
your using using the move tool in conjuction with isoparam selections or uv selections. Maya jsut tells you they cant be moved with the move tool. I must say this request does not come up all that often indeed ive neverseen anyone request it.
Unfortunately you cant supress warnings in the command line, even tough you can suppress the script editor one.
but yes you could catch the tool change take a look at yada yada/mayaN/scripts/startup/changeToolIcon.mel or you could watch selection chnage and print a empty line on selection change too. Problem is that you wouldnt get any other errors visible then either.
There is a dirty trick and its called echo all commands that effecttively flushes this away realy fast tough!
naah.. echo all commands is not a good trick. Some functions are so verbose they actually take much longer with echo all commands. I only turn that on if I really need it.
I remember that i thought about turning of that anoying warning once before. But unfortunately you know.. it must be buit in the commands.
damn. Id have to print " " everytime I switch tools with UV-Components and if I select UVs when a tool like move, rot, scale is on. One could filter this but oh man... why has it be so complicated. I better send a request for the next version..
well, if you are on windows you can edit mayaRes.dll (open as dll resource in visual C++) and simply remove the warning from the string table. Hey presto - no more warning....
Of course, make a back up of the original dll first, just in case.....
woar! Cool idea! See I'm no programmer. Didn't whink of that ^^ ok. I found it via reshacker. Shall I delete the whole line or just the message content?
ok when I delete the whole line there is still a warning: // Warning: line 1: //
hmm.. you know the disturbing thing is not the content, but that there is a glowing, burning my eyes pink bar when it occurs.
hehe.: on one hand you might think: "oh whatta sissy! just turn off the f$%&$&g commandline or let the warning just be a warning and leave us alone with this crap" on the other: there is simply no reason to display such warning 1000times a day. Meanwhile I'm not so dumb to think that I can move UVs in 3D. I dug it Maya! Understood?
