I love DGS
http://jabbaspalace.republika.pl/testdgs.jpg
This is unfinished steamliner. I’ve used DGS material for blured reflections.
Savo
nice. can you rerender it with a texture on the walls and bring the camera in closer?
can you show the settings of the used material ?
is it done with physical light ?
Ok. I will do it as soon as possible.
Savo
http://jabbaspalace.republika.pl/locoDGS.mb
here it is.
Savo
the reflection looks good… but its not blurry.
hence my question… how can i make a blurre reflection without having a grainy surface? the reflections from the dgs are beutiful… but when i decrease the shiny without increasing the glossy… i get no blur… and when i increase the glossy i get grain…
ive experimented with settings of all sorts… and reveiwed the lit… but how can i make a soft reflection without graininess?
the mib_ref node has no glossy setting and when it is incorporated into a shading network… ward for example… the glossy attribute of the ward doesnt effect the refelction? are there any other additional nodes to create this effect? or do i need to look into using a 3d texture mapped into the refectivity to cheat the look? perhaps even a volumetric effect linked exclusively to the refective material?
any suggestions appreciated…
ok i have connected it to MR Material section of a blinn…
if you up the sampling rate it should kill a lot of the grain… 2 4 should do it, though it will vastly increase render times… going over 2 4 will make render times skyrocket without any real significant quality improvement, so 2 4 is, generally speaking, the limit.
