Hi again,
i need help painting the skin weights of my asterix model:
http://img526.imageshack.us/my.php?image=19939142df6.jpg
http://img266.imageshack.us/my.php?image=30878600zc7.jpg
Obviously it is a biped character. It has a skeleton and full body ik.
I tried to weight him multiple times now but I lack the knowledge of doing it right. ![]()
How do I need to approach this. How do u guys weight the skin of a biped character?
Do u go from the head down to the toes?
How must I weight it, where must the 100% influences lie (I think at the center of the joints, right?)
How do I need to weight the torso (spine) area?
I hope u can help me? Thank you!
Hallo!
Basically, there are two ways to go through the skinning of a character. You can start from the root joint at the hip and go down the hierarchy till the tip joints. Or you can do the inverse. Starting at the tip joints and going forward till the root joint. Personally I prefer the second way.
When I start skinning process I put a “gym”-animation on the characters joints. This is a really simple animation on all the free axes of each joint. Don’t overlap the animation, so you can see exactly the deformation of each joint in your hierarchy. Animate in the same direction than you decided to make your skinning. If you are happy with the deformation of one joint you lock his weights. This is really important to keep your work save. If not, the normalizing-process can change the weights of points to get always a sum of 1.
Really difficult are the areas with many different joint influences like the palms, the shoulder and the hips. But don’t worry. It’s normal to do some back and forwards untill you’ll get a good result.
Well, I hope that I’ve been clear! Keep asking in case of problems!
Good luck,
Carlo
thanks for ur support!
And i do have some questions:
When u wrote: “This is a really simple animation on all the free axes of each joint.” Did u mean an animation like when I move the tip of a finger and I then adjust the weight of the used joint?
How do I lock a weight? (I guess I just need to look in the manual, right?)
Hello!
All right. When I said, “simple animation”, I meant a more technical way of moving your joints. For example:
elbow Joint: frame 75 rot 0 0 0
frame 80 rot 0 -90 0
frame 85 rot 0 0 0
wristJoint: frame 85 rot 0 0 0
frame 90 rot 0 -90 0
frame 95 rot 0 90 0
frame 100 rot 0 0 -45
frame 105 rot 0 0 45
frame 110 rot 0 0 0
and so on, and so on…
But these values are only pure invention, you have to see in your scene with your character to find the extreme pose for each free angle of each joint. “Free angle” for me is a possible direction of rotation. For example the elbow can only turn around one axe and in one direction, otherwise it would “break” the bone.
To lock the weights you have to chose your bone in the Paint Skin Weights Tool and under the list you find a huge button: “Toggle Hold Weights on Selected” and this toggles on/off the weights on your bone.
So, good luck!
Carlo
ok, thank u - now i understand what u mean;)
I’ll try it tomorrow and report then. Shouldn’t be too complicated now, only time consuming, hehe
EDIT: Ok now it took me two days to report, but I must say that I worked yesterday as well as today on the weight process and with the method u told me I finally managed to do it right;)
Ok I did not manage to make the model deform like pixar does it but for my first try it looks good enough IMO.
Tomorrow I do the last part of weighting.
Again: Thank u very much for ur help!!!
