I want to do it like this, from the FXPHD tutorial on Renderman 101;
Apparently the Windows Command Line won't do this.
So what do I do in Windows 7 to run Renderman Pro Server 13.5 from a command line?
Yes I know I can run it from Maya 2008,
No I don't want to do that.
Yes I know I can run it from Houdini
Yes I know that I can get 3Delight.
Yes I have it downloaded no I don't want to do that.
Yes I know about Aqsis no I don't want to descend into the hell of Blender.
I've heard there are command prompts/Shells that you can download to Windows 7 that will allow you to go into the Pixar/Pro Server/Bin/prman and give it direct commands by command line...
I'm actually wishing I had a Mac for the first time in my life. They'va actually got a command prompt setup that can just do this..
I want to, need to run Renderman Pro Server from the command line.
Any experienced Renderman hands out there?
Anyone?
If I install Cygwn and then use this will that allow me to run Renderman pro server from the command line?
http://lifehacker.com/362316/use-unix-commands-in-windows-built+in-command-prompt
