Hi.
) I’m trying to do some CharacterSetup in XSI 1.5, but for some reason i can’t see, the chain does everything except bending in a realistic manner. I’m using a 2D_chain of four bones right now, with the second being a pseudo-root. I tried to apply some rotation limits on this bone, but somehow the bones are flipping. Tried to use a stiffness instead, which doesn’t seem to work at all. In addition, when i move the effector, then do an undo, repeat this two, three times, the bones change their rotation values, which sums up, until i got values ranging somewhere around one-, twothousend.
Would be cool if someone got any ideas or ressources concerning this. thanks.
(sorry for the grammarfaults you might stumble onto - i’m not using my english that often at the moment. )
pseudo-root???
don’t do that. use two chains. What are you setting up?
please elaborate.
-Rafe
Hi again. What’s wrong with pseudo-roots? I thought it would be a good idea having the possibility to change my root with it, if I later decide that my chain should bend in a different way.
What I tried to setup was an armbone-chain, that is restricted to the directions a real arm is. Should be simple, i think, but again, somehow it didn’t work with the rotation limits I’ve set.
I now did some kind of workaround, wrote expressions for my limbs and made me a mixer with sliders. I have to see, if it’s easy to animate. At the moment, it looks good to me, and seems to be fast, although my sliders are not as flexible as moving the effector.
I will try a second version with two chains, instad of a pseudo-root, just to see, if it solves my initial problems. thanks
