I have very strange problem in this category. I setup character and made rig for one of the legs(biped) with IK FK blending. Spline selection handle for foot with attribute IK_FK( from 0 to 10, float attribute) which controlls Ik Blend attributes of all three IK Handles(from hip to ankle RP, from ankle to ball SC, from ball to toe SC too). Done by Set Driven Key. Zero value makes leg rig fully IK and ten value makes leg rig fully FK. Everything looks good when I try to weight between IK and FK in static position, but when I animate little walkcycle with IK and want to do some jumps, or spin the character on one leg and second leg to folow with fk(animating only rotation of joints), blending makes some strange values in rotation of joints ... Does anybody know this problem or met it in past? Thanks.
idea of setup described was ok, but results sound weird.
i guess problem is in rig of FK leg. make it visible (perhaps hide skin and attach polyCone to each FK bone too) and check its behavior while animating in IK mode + translate root - there could be double transforms because of incorrect hierarchy.
I think the problem is not in hierarchy, because FK is not fully rigged. It is extremely simple: I only displayed selection handles of joints I want to rotate in FK mode and I am animating rotation channels of these joints. Maybe could be problem in Ik Blending of all handles at once. Everything is driven by one attribute ....
its really hard to figure out this way when not touching very cause of problem. if You could post .ma with animated skeleton it could be easier.
