I am trying to use an image plane as a template to model over. I have adjusted the depth of the image and looked for possible settings to adjust, but when I attempt to draw a curve over the image, my line is hidden in the top view. Is there a setting change that will allow me to see my curves over the image?
you may want to take a look at this tutorial, the freebie
http://www.gnomononline.com/modeling.html
also instead of using image planes you may just want to use planes and map the picture on them and then put them in a layer. I picked that up at
