I have a image sequence with 190 frames, all .iff files. I put them as a sequence in a shader and onto a face. when I make a previewrender everything looks good, also in the viewport I can see the images on the surface. but when I start the batch render I just get a black face.
a tip woulfd be that renderer sees different project environment? And thus the relative file naming convention will not be found. Specify the -proj flag.
QUOTE(Joojaa @ 01/02/06, 12:39 PM) a tip woulfd be that renderer sees different project environment? And thus the relative file naming convention will not be found. Specify the -proj flag. [snapback]223759[/snapback]
thanks for the reply, how do I specify the proj flag?
