My studio is very Maya-centric, but we will be d3ealing with client assets created and animated with XSI…Is there any possibility of transporting these assets (characters with rigging ) intact into Maya, without resorting 3D programmers and custom engineering?
well you might beable to use FBX filmbox to export files from one to the other but it may take some work and patience
would this require the client to export the FBX files for us? (we have no in house copy of XSI)
I assume that other formats (?DXF) won’t include rigging data…
you’ll be dead in the water with anything but FBX and to be honest without some tinkering in XSI I doubt the transfer is going to go easily.. I hope the client is willing to work with you on this..
get the client to export a single file to see if it will work, tell them to turn off any smoothing on the character because FBX with convert smoothing to geometry and things will get out of control fast.
QUOTE
Depends on the complexity of the rig. But if its more than a little complex then ist usaully easier to build it more or less form scratch in maya.
Also its not necessarily smart to do this the style of people and applications varies a bit so its better to adapt than directly mimic.
But if your buying this asset its not necceserily sane.
