Imported IGES File Groupings
I’ve imported an IGES file into Maya that is composed of a number of different objects. If I click on one of the objects in particular, it is made up of 3 separate objects that do not overlap. They appear to be separate objects that are grouped, but when I try to ungroup, nothing happens. Any suggestions on how I can break this “compound” object?
The surface shapes might be part of one common transform (open up outliner and enable shapes), if so you can duplicate the transform and delete the shapes so that each transform only has 1 shape.
