Importing LW meshes/UVs
Still waiting for 1.5. Can’t wait to crash-test those Subds. Modeling and Texturing in Lightwave 6.5 is phenomenal IMO (too bad the animation toolset is short one animation mixer). Anyone know if it is possible to get a mesh from Lightwave to XSI 1.5 with discontinuous UV’s intact?
The only way i can think of that “I would trust” - is using polytrans. - you could try obj export from lightwave - but i dont know about that.
  • Non smokers die every day.
Hi Fezzini,
Dont need to use obj .
the most straightforward way is to get this free hrc exporter plug-in from
DStorm’s website at:
http://www.dstorm.co.jp/~taz/plugin65.html
this will save a hrc file of your LW mesh.
The critical thing to remember is to save it off to a
an existing Soft 3.x database folder (models) otherwise
XSI will only use a null object in its place.
Incidentally if you want to bring the hrc into Soft3.x you can
save it anywhere.
I dont know how well the hrc exporter handles UV data
although there are options in the interface.
If you still prefer to build your low res cage in LW this
can be brought into XSI for subdivision/geometry approximation! (Note unlike LW, XSI doesnt need quads for
subD’s)
Hope this helps.
Dave K
Thank you.
