Hi,
I've been using ReelViz Matchmover quite a bit to perform 3d tracks
for the lightwave guys. I noticed in this newest version, I am able to export
combustion workspaces. When I do this and open this exported cws in c2,
initially everything looks cool; all of the track point nulls line up,
and it appears the track works. The problem surfaces when I try to import
another layer into the shot. It is revealed that the tracked plate is miniscule,
so when you import a new layer, you can try to shrink it to 1% scale and atempt to position it in the tracked scene, but inevitably this new imported plate slides away.
Has anyone else seen this? Anyone had success with Matchmover cams in c2?
I'd love for this to work...
Thanks,
jon a
