Bateman yes i know that hes witing a ma file. I do it all the time
QUOTE(bluntman @ 08/22/06, 11:48 AM) [snapback]245808[/snapback]
a) because .ma files use MEL commands to construct the scene
Actualy its just a bit of a subset of mel
And indeed the ma file contains stuff thats not valid in mel! Or atleast its not doable inside a maya session.
Still i vote thei sia api question, because api is about program development, regardless of the fact thet your wiriting MA file.
Yes, bateman is right your handedness looks opposite. Your calculating a typical architecture space while mayas using what most eingeeneers use. this means that your rotations are opposite amongst other things (sich as z being in opposite direction)
Wonky:
Maya uses the notion that pivot isnt necceserily at ttransfrorm this maens maya may show you a objects transofrm hadle at a differebnt place then it is. But this does not affect bones.
