Influence object vertex keying
Hello,
I'm using an influence object. In the channel editor I select all transformation parameters (move, rotat, scale, x-y-z), then I made keys, it's clear and works. But how can I make keys for vertexes of the influence object? I would like to modify the influence shape as well to set up the volume. Thank you
example:
setAttr "skinCluster1.useComponents" 1;
yes, thank you
