Inherate Camera Frustum For Spotlight
Hello Gurus,
I would like to position a spotlight on the position of my camera, and use barndoors to narrow the field of view to the exact size of the image plane attached to the specified camera.
As a test i was able to manually put in the values of the camera and possition the barndoors to about the size of the imageplane. But hey this is maya there should be a cleaner way like link the placement node to the spotlight.
Or maybe i'm just on the wrong track here and there is a better way to do multiple light projections for baking.
Regards, thanks
Dawn3
Oke...........found the solution
It did not work before because i could not make the input nodes visible
connectAttr -f coordicam.translate spotLight1.translate;
// Result: Connected coordicam.translate to spotLight1.translate //
connectAttr -f coordicam.rotate spotLight1.rotate;
// Result:Connected coordicam.rotate to spotLight1.rotate//
This did the trick. Maybe it will help someone else
Regards,
Dawn3
