I'm a fan of splineIK for anything that is snake or rope-like.
Create the joint chain using a say eight to ten joints.
Skeleton-->SplineIK-->[option box]
reset settings, uncheck 'auto parent curve'
select the root joint with the pointer and then the end joint with the pointer. This runs splineIK down the joint chain. Hide your joints and IK handles and select the curve. Right click on the curve-->vertices. Select a vertice and go deform-->create cluster. Do this for each cluster. There should be four.
Make three controllers. One for each end and one for the middle of the joint chain, somewhere between the middle two cluster deformers. Parent the clusters on the end to their respective controller and then parent the two clusters in the middle to the controller in the middle. The controllers on the end will keep the joint chain stuck in place (unless you move them) and will follow what they're parented to. So you could parent the top one to the head controller and the bottom one to the chest controller (or whatever is convenient and works). You can parent the controller in the middle to perhaps the top controller.
You could also group the controllers and write a script in the expression editor so that the middle controller moves at a proportional rate to the top controller. Such as
middleControllerGroup.rotateY = topControllerGroup.rotateY / 2;
You can move the middle controller to get secondary motion on the middle of the cord. If you do not want secondary motion and want things to be very easy, you could skip the controllers all together and parent the top two clusters to the head controller and the bottom two to the chest controller. This would allow for no additional motion but would have the joint chain follow whatever is moving.
Make sure you take the splineIK and curve that was created and group them and make a group called something like doNOTmove. These should not be parented to the rig heirarchy or things go screwy.
Optional for SplineIK
To allow for stretchiness in the cord you can create some nodes to make the cord stretch beyond what would normally be possible. This also allows the rig that has splineIK to be SCALED, which is handy.
select the curve
in the command line type
arclen -ch 1;
In the hypergraph click 'input and output connections' and hit 'F' to frame the selection
find the arcLength node;
open the attribute editor and make a note of the length of the curve
in the hypershade under the utilities tab create two multiplyDivide nodes
open your connection editor
on the left load arcLength node, on the right load the first MultDiv node, MultiplyDivide1
connect the arcLength.output1x to the MultiplyDivide1.input1x
in the attribute editor set both nodes to Divide and in the first one fill in the input2x with the arcLength number you took note of
now in the connection editor
on the left load MultiplyDivide1, on the right load the second MultDiv node, MultiplyDivide2
connect the MultiplyDivide1.outputX to the MultiplyDivide2.input1x
on the left load the rig controller, keep the right the same
connect the rig.scale to the MultiplyDivide2.input2
on the left load the MultiplyDivide2 node, on the right load in each joint in the SplineIK one at a time and connect the node's output x to the scale x on the joints:
MultiplyDivide2.outputX to the yourJointName.scaleX
Now the joint chain can be squashed or stretched and the rig can be scaled.
I hope this helps. If you have any questions, feel free to email me.
tpayne21@student.scad.edu
