Intersection Always Fails With Nurbscone
Hi, I am using Maya 8.0 and am playing with the intersect command. Interestingly, the intersect command can't find intersection between a nurbsCone and other nurbs Surfaces even when I obviously set the objects to intersect, e.g. plane, sphere. ( intersect -ch 0 -fs 1 -cos 1 -tol 0.01 -o 1 nurbsCone1 $obj2).
when you create the nurbsCone, if you type in 'cone', the intersect command works perfectly and returns the curve created by the intersection. but if you create the cone by clicking on the toolbutton (setToolTo "CreateNurbsConeCtx"), and then intersect, maya always responds no intersection found.
Does this happen on your computer too?
