I want to create a visual control for the uValue of a motion path. I made a control object that is geometry constrained to the motionpath curve. I was wondering if there was a way to connect the xyz coordinate of the control object into a pointOnCurveInfo so that it would output the parameter. Right now, when I try to connect it, its gives me
// Error: The attribute 'pointOnCurveInfo1.position' cannot be connected to 'pCube4.translate'. //
I would then connect the parameter to the uvalue.
Then again, if you have another solution to solve my problem, you<re more than welcome to share.
Sure use a contraint then sue a point on curve info node to obtaim the value nearest.
However you could consider just making the trasforms default manipulator the path anims manipulator instead. (it accomplishes same thing) And irts doen by default so jsut use the show manp tool! (as for making animation would be best if the animator only ever needed to enable show manip tool)
