Hello!
I tried to replicate Maya camera 4x4 projection by extracting camera attributes, but I am not quite sure how maya calculate its projection matrix.
Comparing with the projection matrix obtained via open maya function(MFnCamera projectionMatrix),
The first cell (cam(0,0) ) is different. Not sure what is the way maya calculate its projection matrix.
Also I haven't consider the camera film offset(cameraShape1.horizontalFilmOffset and cameraShape1.verticalFilmOffset)
and film roll value (cameraShape1.filmRollValue)
Here is my comparision code.
Is anyone have idea? Thank you!
import maya.OpenMaya as om
import maya.cmds as cmds
import math
import maya.mel as mm
def getProjectionMatrix(camera):
cameraShape = cmds.listRelatives(camera, children=True)[0]
list1 = om.MSelectionList()
list1.add(cameraShape)
depNode = om.MObject()
list1.getDependNode(0, depNode)
camFn = om.MFnCamera(depNode)
pMtx = om.MFloatMatrix()
pMtx = camFn.projectionMatrix()
cameraMatrix = []
for i in range(4*4):
cameraMatrix.append(0.0)
for i in range(4):
for j in range(4):
cameraMatrix[i*4 + j] = pMtx(i,j)
print("This is the camera projection matrix obtained via Open Maya")
print(cameraMatrix)
myCameraMatrix = []
myCameraMatrix.append(0.0)
command = "camera -q -hfv " + cameraShape + ";"
fov = mm.eval(command)
command = "camera -q -vfv " + cameraShape + ";"
vfv = mm.eval(command)
command = "getAttr " + cameraShape + ".verticalFilmAperture;"
verticalFilmAperture = mm.eval(command)
command = "getAttr " + cameraShape + ".horizontalFilmAperture;"
horizontalFilmAperture = mm.eval(command)
aspectRatio = float(horizontalFilmAperture)/float(verticalFilmAperture)
command = "getAttr " + cameraShape + ".nearClipPlane;"
zNear = mm.eval(command)
command = "getAttr " + cameraShape + ".farClipPlane;"
zFar = mm.eval(command)
command = "getAttr " + cameraShape + ".preScale;"
preScale = mm.eval(command)
command = "getAttr " + cameraShape + ".postScale;"
postScale = mm.eval(command)
command = "getAttr " + cameraShape + ".filmTranslateH;"
filmTranslateH = mm.eval(command)
command = "getAttr " + cameraShape + ".filmTranslateV;"
filmTranslateV = mm.eval(command)
xMax = zNear * math.tan(math.radians(0.5*fov))
#xMin = -1*xMax
yMax = zNear * math.tan(math.radians(0.5*vfv))
#yMin = -1*yMax
#yMax = xMax / aspectRatio
#yMin = xMin / aspectRatio
myCameraMatrix[0] = preScale * postScale * ((zNear) / (xMax))
myCameraMatrix[1*4 + 1] = preScale * postScale * ((zNear) / (yMax))
myCameraMatrix[2*4 + 2] = (zFar + zNear) / (zFar - zNear)
myCameraMatrix[2*4] = filmTranslateH
myCameraMatrix[2*4 + 1] = filmTranslateV
myCameraMatrix[2*4 + 3] = -1.0
myCameraMatrix[3*4 + 2] = (2.0 * zFar * zNear) / (zFar - zNear)
print("This is my projection matrix")
print(myCameraMatrix)
The result i got is something like:
[3.7144701480865479, -0.25955617427825928, 0.0, 0.0, 0.19466713070869446, 4.9526267051696777, 0.0, 0.0, 1.6421337127685547, 1.9714449644088745, 1.0033389329910278, -1.0, 0.0, 0.0, 20.033390045166016, 0.0]
[3.1740308789637033, 0.0, 0.0, 0.0, 0.0, 4.9594232483807872, 0.0, 0.0, 0.0, 0.0, 1.003338898163606, -1.0, 0.0, 0.0, 20.033388981636062, 0.0]
