Hi,
I'm moddeling som stuf but i whoud like to export is in a isometric perspective... does some one know how i can do that?
I tried the F1 function but i didn't find anything use full...
if normal isometric is enough then just make a orthographic camera and rotate it so its slantted but know this by default teh tumble tool is forbidden to interact with orthographic views (orthographic is isometric), you need to edit teh tomble tool options to allow this.
However no arbitrary trimertric projections are available.
Just turn a perspective camera orthogonal and set the rotation to -45, 45, 0.
That should be all, just make sure your camera is far enough away from your object so nothing is clipped.
Cheers
Chris
thanks for the help..
