Isometric view in Maya?
Does anyone know how to set an isometric modeling view in Maya? We are switching from Max to Maya and our lead modeler wants to use what is called a "user" view in Max, this is a 3D view that does not have any perspective.
I have never felt a need for such a view as I use maya orthographic views to adjust proportions but he is used to doing all this in a "user" non perspective 3D view.
I haven't looked into this yet but any help is appreciated.
I
Your lead animator/modeler is in for a bit of frustration here...
I too came from MAX to Maya almost 2 yrs ago and that was one of the most frustrating aspects of Maya for me at that time (I use the MAX user View to model as well).
To get a user view in Maya you can go into the perspective view or another pre-built orthographic view (Make sure your viewport panels are showing! to toggle this press shift+M) and go to View> Camera tools> Tumbel Tool and uncheck "Locked" under orthographic Views and also "Stepped" if you wish.
This will only affect the view your in or really the Camera your viewing from. Unlike MAX, Maya uses a real modifiable camera for all views and looks at the Tumble Tools settings for global behavior.
Keep in mind that once you've unlocked this, all the viewports are able to be "Tumbled" and getting back to your original Top viewport is a bit harder than it is in MAX. To go back to a previous view press "[" or forward press "]."
*** I tried using Maya this way for a while and decided it was just apaint in the butt so I got used to using Maya without "Users views" but I want to stress that the Perspective View in MAX is awful compared to the one in Maya and really you'll eventually find that you don't really need a user view in Maya like you do in MAX and general viewport navigation is superior to MAX because it's the same in every GUI inside MAYA.
TIP: If you want to use "User" views in Maya you should setup a "Bookmarks" so you can get back to the original true orthographic views. Becareful not to think your in a true orthographic "Top" view even if it still says "Top" in the viewport it could be tumbled a bit and you don't realize it.
Hope that helps...
My thoughts on this issue are exactly the same as STZ's. I loved User/Iso view for modelling and it took me a long time to get used to working in a perspective view.
Now that I have acclimated, looking at an iso view is really hard for me.
--JeffD
Ye stz your partialy right. Theres one other thing too the view mwnu contains predefined bookmarks in case you ever modify anything and want to go back!
Sorry cant remeber the path since ive modified my viewport menus so that the bookmars is directly visible in the menubar, not asubmenu, should i ever wnat to look one up! Since i saw it was usefull. But rarely use it anyway. But its one mod id like to se on many many more comps!
I'd like to add this because we're on the topic...
Maya only shows you a "Top" "Front" and worst of all "Side" view. I've stated this gripe before but which side? If a new user has started a scene with just a sphere and also like I; coming from a coordinate system where Z is up, the "side" view means almost nothing to them.
In Max they use "Left" "Right" "Bottom" "Back" which I have found no reason to abandon at this point.
Jooja, I and don't know Mel well enough; how would you modify Maya 4 and up to actually say "left" "right" or "Bottom" in a viewport based on the pre=defined views?
Thanks
Hi.
I found this script "seven_cameras" very usefull.
