For some reason I can't select only part of an isoparm.When I selecct an isoparm it selects the entire line.How do I only select a small region.?
Hi.I don't think it's possible.You can either detach the surface to make it a small portion or use polygon.
yea, thats not how NURBS work. An isoparm is an isoparm. There is no..."section" of it.
hmmm>> I must be confused then.
I got the idea from this tutorial.
http://www.polyextrude.com/tutorials/model...r/CharTut3.html
Its on page 3, the scetion that says.
Detach geometry like such first (horizontally)
Then split vertically
Ahh...I see what you mean.What they are going is cutting the torso in to seperate peices.
In maya you do this by:selecting your isopram and under modeling/edit curve/detach curve
