Cheers for the reply. My cache filename was indeed huge, so I re-named it to something far more sensible. Doesn't seem to be the cause the cause of my problames, however, as I mentioned earlier, the jiggling all works as expected when there are no transformations on the character (it's all FK'd), but it's limbs are a moving away (running on the spot). I could tell you the exact number for the various settings, but since I've tried virtually every variation and combination under the sun, without any real change in the behaviour of the jiggling there doesn't seem to be much point. Only the jiggle weight setting bahaves normally, scaling the effect from 0 to 1 as you would expect. Anyway, time has run out for me on this one unfortunately, I just hope I have more luck next time I try it out.
cheers for the ideas.
TomB
