OK, I just manaully rotated all the trouble joints 180 in Z, so that the X axis went from pointing down the joint chain to UP the joint chain. Its screwed up in the exact same was as before I rotated the joints. So, rotating the joints 180 has no efffect, nor does playing with the orient joint tool. Anyone have any other ideas, or perhaps I made an error somehow.
Screen: http://users.rcn.com/rmkerr/Stupid_jointshttp://users.rcn.com/rmkerr/Stupid\_joints
(Damit, I hate being stuck like this when all I want to do is work) Pleeeez help.....
edi: OK, I noticed something that might help someone help me. When i import the joint chain, I group it to itself. So, it has a clean channel box. The joint in the skeleton that it gets grouped to has a relatively clean channel box, just some slight transform, which I think is usual with joints. Now when I group the group node to the skeleton, the group takes on some craze attributes in the channel box: 133 rotate in x, -1 scale in Z roate 90 in Y etc...while the joint, in the branch, immediately below this sloppy group node is relatively clean. WTF?
