Hi all!
I'm having a small issue when setting keyframes. I've found for some of the keyframes I have set, the interpolation is a bit crazy. There is no frame between the two keys. Essentially the first key is on frame 1 the second is on frame 2. The value of both keys are the same, but the curve between the keys makes this huge spike.So, I select the keyrames in the graph editor and try to change the interpolation to "flat" but the huge spike is still there. In other words nothing happens when I try to change the interpolation.
Obviously it's not that big of a deal since the values are the same on the frames themselves and they're right next to each other, but this is going to turn into a problem if I want to scale the animation. (Plus, I'd really just like to know what is going on with it)
Anybody know why Maya won't listen to me?
(Also I don't know if this matters, but I'm using the human IK rig.)
