I've come across some DV footage that needs to be keyed. I can key it great in After Effects with Keylight (thanks in part to the screen pre-blur feature). I'd prefer to use Shake, but have run into a problem. Keylight in Shake, to the best of my knowledge, doesn't have a pre-blur function.
I've tried blurring the blue channel of the source footage before feeding it into Keylight, but then there's a rectangle around the border after it comes out the Keylight node (or Primatte), I guess as a result of black being brought into the edges from the blur and not getting keyed out. I know I can rotoshape this out, but when the subject is along the border, they partially disappear.
Alternatively, I've fed the footage straight into Keylight, edge detected the resulting alpha channel and used that as a mask for a blur. This works okay, but doesn't look as nice as pre blurring the blue channel.
So I'm in a predicament: gray rectangle or sub par alpha channel.
Is there something I might be missing that would let me pre-blur the image before keying without the rectangular ring? Thanks!
