Thanks! these are good ideas!
But i had to solve it myself, because delivery date was 2 days ago...
but for sure , next time i willgive it a try
for the light warp on the edge portion, ive tried it, and it was only adding light and making the edge brighter, wich is the opposite of what i wanted to do....
but here is how i managed to acheive something lokking good:
i did is a diffrent key, with a hard edge, excluding the motion blur... then, i piped in an XoR two version of this alpha : one slightly blur and another eroded and blures... so i got an edge matte, wich i blurred and tweaked to get it as thick as the motion blur area, and with a smooth softness, but starting inside the character and finishing on the solid edge....
then i pipe this alpha in a swichmatte,using as source the greenscreen version with the despill from the huecurve, and comp this over the same greenscreen despilled footage.... placing a move2D between the swichmatte and the over node, i offset the "edge patch" to hide the motion blur area, and did a bit of roto to delimit this "patch" and then i use this new patche plate as my source footage in the switchmatte... so i kept my softness with to good looking color that was supposed to be there......
Then yesterday, i've talked to the effect supervisor for 300 at my job, and he gave my extra tips that i think might be good to share....
he told me that i could have played a little bit more with the green hue curve inside the hue curve node that i used, to match the luminance of this area with my comp .
second, he told me that a hard edge key comp on top of this same key, but blurred a lot could do the job......
and last, as HueSatVal suggested me, to comp a version inside the keylight node, connecting the background would help to blend the edges, and then combining this key with other despill versions, with hard edges on top.... or simply to start where i was at the begining of this post, with something soft and then pipe a primatte after my swichmatte and key the grey line, to get controll and mor transparency on it
Thanks guy for sharing with me, and hope this thread will help others with the same problem
