Hi to all!
I'm trying to make a lake with pond! I want the water more trasparency where the terrain is less deep near the border of the water. I need it also for a normal surface like polygon or nurbs! Can someone help me?
Create an ocean with a wake. If you make the wave height and numFrequencies on the ocean zero then you have just the fluid wake, which is the same as the pond, only with a tessellated surface. Assign the ocean shader to any desired geometry( if you don't want to use the default large circular plane ). If you raytrace the ocean shader with transparency it will be more transparent where it is thin.
Duncan
