Last Frame number
I want to know if it is possible to get, to recuperate the number of the last frame in a scene. I want to do this with a mel command....
Thank you
TonyBoy
playbackOptions should let you know, range or whole animation (not sure if you can globally query for the last keyframe).
I had to do this very thing this afternoon, so here it is:
	int $startFrame = `floatFieldGrp -q -v1 startFrame`;
	int $endFrame   = `floatFieldGrp -q -v1 endFrame`;
	int $frameStep  = `floatFieldGrp -q -v1 frameStep`;
	int $numbOfFrames = (($endFrame - $startFrame) / $frameStep);
	int $lastFrameNumb = ($startFrame + ($numbOfFrames * $frameStep));
	print $lastFrameNumb;
This is assuming you want the render globals last frame. It would be easier just to query the gui if that is what you are looking for.
BTW , you need to source (or just open the panel) the render globals panel.
Hope it helps...
Thank you for your help.....
It works well and I learn a new mel command
