Latest methodology for changing Geforce/2/3 drivers
I haven’t really been keeping up with the latest advice on changing video drivers on Geforce/2/3 series cards. I know that a while back it was advised to change to “Standard PCI” drivers as a first step, and a “full uninstall” of various files and registry entries was always considered a good idea. However, it seems like I’ve seen less and less talk of those procedures over time, and the latest “instructions” I see say to simply install the new ones right on top of the previous installation with no special procedures. What’s the latest consensus on this now that we’ve moved forward to the “Detonator XP” series of drivers?
Also, are the “auto installing” drivers from Nvidia still trouble? The last couple times I used these I ended up with some of my Display Properties tabs missing – I had to do one of those “complete” uninstalls and manually install the new drivers to get things back to normal. Is it still recommended to simply unzip the auto installer’s files into a directory and “manually” install the drivers?
Thanks for information on this subject,
Larry
If you are running Windows 2000 or Windows XP, then you can go ahead and just install over the old ones, as these these 2 OS’ are smart enough to figure things out.
I myself haven’t had a problem with the Detonator XP self installing setup routine, but if you want to make sure that these drivers have isntalled themselves right, open Display Properties and look into the “Settings” tab and click the “Advanced” button and then click the tab that says “GeForce2 …” (depending on what your card is) and then you’ll see a file list of your diplay drivers. You can then make sure that all the installed drivers are the same as the version you installed.
