Lens flare removal
I'm working on a shot which requires the removal of a lens flare across multiple surfaces and I'm wondering what would be a good technique to use. I'm against using the clone tool, because it always results in a vibrating effect. Right now I'm rotoing out the shape and applying an animated color correct node depending on the area the flare is traveling over, yet this is still yielding less than perfect results. Does anyone have any suggestions?
Depending the camera move I usually just create a clean plate and track it back in.
