ok, here’s another clear illustration of this issue:
do you know what is causing the weak FG spread of red color in the second image?
neve mind the fisrt one:
nevermind this thread.
the issue is solved.
one has always to use a gamma correct node for Maya swatches even when rendering to a float format. the second render is actually the “right” one
Its the gama correction that is doing its job. If you do not gamma correct you will end up with over pronounciated color bleed.
Simply put
0-25+0-25=0.5
BUT 0.5 is not necceserily linear so because the camma correction that our natural monitors have it pushes it up to something else. In case of a srgb monitor. 0.72. But what the renderer intended was really 0.5 wich offcourse is weaker than 0.75 by heaps.
_
