It would not be hard to write a MEL script that turns off the light sthat are not linked to the object that you want to bake. Would that solve this problem for you?
Well unless it’s equally important to see the specific object in relationship to the other objects with different links then this would work for previewing.
Outside of that I think this would require programming a plugin and I have no idea if the API would allow this kind of improvement to the OpenGL render. THis may be a limiatation of OpenGL rather than Maya.
"Well unless it’s equally important to see the specific object in relationship to the other objects with different links then this would work for previewing. "
Well, yeah thats the point. To see the relationship with other light linked objects.
I had considered that it is a limitation of GL, but I wasnt sure and wanted to explore other avenues..
Seems to me if you can render linked lights, then you should be able to at least get a rough preview in the persp view… seeing as you can get realtime preview of lights in “7” .. why not linked lights?
Cheers,
Brad
I wote thats it a limitation in openGL… not sure tough Anyone? Altough to be hones you could do it in opengl with multipasses… but itd throw speed right out the door!
