Hello,
Have made some holes in a polygon surface using a UV map attached to the shader's transparency node. Looks fine, trouble is that no light seems to pass through the holes (the shadow looks as if there are no holes in the surface at all).
Is there a box to tick somewhere to allow this to happen (in light settings, render settings?)?
Can this happen at all?
Thanks,
Matt
