nadaa,
works fine here.. some things to make sure you're doing are:
is the RPF layer in front of another layer? make sure it is far enough in front to actually cast a shadow! set z transform position to something like -50 to put it in front of the other layers..
also, mae sure you're lights are set to cast shadows.. under settings/render effects, make sure shadows is checked..
-Matthew
