Hi Spartacus,
Unfortunately I don't know if you can move the infinite light's origin, but I can assure you that it does not matter, since the light is "infinite" (!) The light will project light in one direction, but on a infinite scale.
BUT, if you absolutely want, no matter what, to control the light from the center of your actual scene, you can:
1- Create a null in the center of your scene, then create another null placed on your light, make the second null child of the first, and apply a position constraint to the light onto the child null. So you'll be able to move the light from far away
2- Set up an expression telling the light to move accordingly with a null placed on your scene.
Hope this helps
Bernard Lebel
