Limit memory use?
Hi, just wondering if there was a way to limit the amount of memory that Fusion uses, like in After Effects and if there was a way to purge image caches like in After Effects.
thanks
hi Harlequin,
Answers for both question:
  1. To setup memory limitation go to:
a) FILE --> PREFERENCES
Switch to "Globals and new comp default" drop down
c) "Memory" and you are set.
  1. To purge RAM CACHE right click (right bottom corner next to IDLE status) and "Purge Cache"
    You can do it at any time, even while rendering.
