Hello people,
Let's say I have several partitions, each with an override. In these overrides, it's always the same parameter (in this case, the Radiance parameter. I connected a color savestate node in the override's input). I want to connect together the values of all the color savestates nodes, so just changing the first color savestate will change the values of the color savestate of all overrides. However, in the Explorer, I can't seem to find the color savestate parameters.
For instance, even with all nodes turned on, if I expand the override node, the farest I can get is to Override > Entries > entry > material-Photon-out-radiance.
Is what I'm looking for achievable, or am I looking at the wrong place?
Thank you for your patience!
Bernard Lebel
