Hi ,
What is the MEL command for listing "Quick Sets" or "Quick Select Sets"
Thanks
Chayan
Hi ,
Thanks
Chayan
You might have a look at this:
http://www.uberware.net/mel/#selectionEditorWin
Theres actually no difference between a quick selection set and and other set types (they can all be used for quick selection a set is just a container and as a container quick selections dont differ form other container they are as fast too), tough sets created trough the menu as quick selection set have a type falag set to gCharacterSet to separate them form others (this is arbitrary you could have different kinds os quick selection sets if you wanted to).
ls -sets; //list all sets
ls -et objectSet; //just object sets
finally let us assemble a filter to do a search for gCharacterSet types. A filter is (more versatile and usefull isll show later how you can hook this to outliner):
//first lets define a proc that collects the data
global proc string[] allGCharacterSetNodes( string[] $name ){
string $ret[];
for ($item in ls -et objectSet)
if (sets -q -text $item=="gCharacterSet") $ret[size($ret)]=$item;
return $ret;
//lets make it a filter
itemFilter -ss "allGCharacterSetNodes" gCharacterSetNodes;
//now you can get them all with
lsThroughFilter gCharacterSetNodes;
//or you can just connect it to a exsisting editor ala:
tearOffPanel "Outliner" "outlinerPanel" false;
string $outliner = outlinerPanel -query -outlinerEditor ;
"outlinerPanel1"
outlinerEditor -edit -filter gCharacterSetNodes
$outliner;
//it doesnt have to be outliner mind you
now you could proceed with making a selection connection
that selects the contents of each set on click if you wish.
