Maybe I’m getting behind the times, but what ever happened to the Polys/sec spec.?
When I went to Siggraph in 2000, nvidia was boasting a whopping 150M Polys/sec for the then up-and-coming x-box. And in 2001 someone ran a demo for Final Fantasy movie in real-time with the Quadro DDC.
I’ve scoured many sites, but no one makes mention of what the polys/sec specs are for any of these later cards. Everyone just seems to cut and paste the specs from Nvidia’s site - and they are telling the triangle rate.
Does anyone know the where to find the polys/sec specs, or why they don’t get posted anymore?
From a high-end POV, what is the best spec to determine how smoothly a card will run OpenGL apps?
-polys-per-second benchmarking is not a terribly accurate way to determine actual rendering speed.
Everything must get, shaded and lit before they it is viewable in almost all cases, adding considderable computing overhead to the process -and thus slowing the actual throughput.
Also, triangulation of the geometry doesn’t always come from polygons. Some drawing techniques use b-splines or other curves/patches to define the geometry before is is tesselated into triangles (or quads).
“And in 2001 someone ran a demo for Final Fantasy movie in real-time with the Quadro DDC…”
-if you saw that at the Sony booth, what you saw was 32 playstation “emotion engines” rendering a FF scene in Parrallel -and being output in HD in realtime.
