Living Maya Post Not Clear
Hyello,
There is an answer in the living Maya thread about half way down that reads “how to rotate the pivot point” or something similar.
The Answer is to go into component mode of an object and then depress i think the Question Mark in the toolbar which is for miscellaneous.
It then says you should be able to rotate the pivot.
I can’t get this to happen. I can’ figure out how to rotate a pivot, as soon as I hit the rotate tool I get the rotate manipulator and get knocked out of pivot mode?
I was trying to figure out how to do this so maybe you could scale and move objects/components in 1 direction not orthogonal or local to the world object but in a random direction.
You can in MAX by setting your coordinate system to “screen” then orbiting around your object and moving components etc. Note: I know you can do this by clicking on the yellow axis switch too hikey but You don’t get that option with the scale manipulator only allowed to scale along x or y or z and definately not xy or yz or xz.
Later,
Jason
Well i think they might actualy refeer to the rotate pivot not how to rotate it. ok ill anwer this and have a looksee.
Anyay its realy bad thing to start manipulating the local space… because on the long run, esepecialy if you make many changes to this. Maya wills start loosing precission. Not that it often matters but the filosofy behind this is solid.
realy the pivot is not totaly in local space but the way maya handles this sometimes is a bit confusing!
its much better practice to use a empty group rotate that and parent thisway you can have two different local spaces without needing to go into this.
