hello everyone, I need your help.As indicated in the title, I want to load variables from a text file. I'm writing a single script.At first, I generate a text file "C:/tmp/variable.txt" , (with a fopen) in which there is this:
string $VARMAX[] = {"nurbsSphere1","pCube1","nurbsCone2"};
secondly, I load it:
source "C:/tmp/variable.txt";
print $VARMAX;
it is now that the problem happens. If my file "C:/tmp/variable.txt" doesn't yet exist, Maya will tell me 'Cannot find file'. Logic.
So I try to put the command in a 'evalEcho',
pause -sec 1;
evalEcho "source \"C://xdk//variable.txt\";";
print $VARMAX;
I have this message: // Error: Line 3.14: "$VARMAX" is an undeclared variable. // as if it was a procedure.
I need to have this text file to use it instantly or later.
