Hi,
I am going to work with film footages and i try to find the right process.
I am ok with the lin log but not with the display.
I some tutorials i found that i had to change the rNgamma and the rDgamma to 1
the picture looks okay, but i don't know if i am close of the real final projected picture.
We have an other workstation with combustion who have a lut preset for film
I know that i have the lookup in shake but i don't find the utility to use is because i can correct my picture look with the gamma, so what is the best way ?
i read somewhere that i had to change to black and white point on my settings,
by default in shake they are 95 and 685, some tell that changing that to 0 and 1023.
ok, ok, what is the better way ? if i do that and check my histogramm, there is a little change between the in and out picture and without changing the black and with (only the gamma) my histograms are the sames
conclusion :
I think i just have to find the good settings in the linlog node (do the same at the end) and don't use the lookup.
if people have experience with, please help me.
Thanks
