Long and short attribute names
hi all,
is there a way to return a selected attribute from the channel box using long attribute names. When i query the selected attribute using channelBox -q -sma it returns "tx" for instance, when what i need is "translateX". Is there a way to do this ?? Or is the only solution to have a function that will check the string and alter it accordingly (which is what im doing at the moment) ?? Any help would be much appreciated. Thanks in advance :slight_smile:
