ok....say i want to make a cloth animation that is 60 frames long.....is there a way to set up the cloth so that when this animation loops it appears to be seamless?
much appreciation for anybody that can help me on this.
casey
casey
Bump
I'm also interested in looping an nCloth simulation. Any info would be greatly appreciated.
i was wondering if there was a way to blend two clips together or something.......not really sure how all that works, though.
glad this post has been re-vitalized!
has anyone found how to create a loop with ncloth im trying 2 do the same thing as the guys above thanx
You could try animated the Input Mesh Attract value so that your shape at frame 1 is the same as the shape at frame 60.
Hi,
Sorry if it's too late, but you can do a long sim (200 frames), cached it.
Chop it up into 2 sequence (just rename them), example:
from cacheA.0001 to A.0200
to cacheA.0001 to cacheA.0100 and cacheB.0001 to cacheB.0100
blend two cache files together and cross fade them somewhere in the middle. I used them all the time.
(The final shot is 100 frames but you can loop it endlessly)
Good luck
