hi,
i got a problem when animating with sound turned on. When i loop through scene a couple of times (and, when synching, you got to go back and forth a lot), i'm starting to loose FPS, it feels like maya gets jammed or something.
To exclude all other problems (slow rig or other scene issues), i tested on a empty scene, with just a sound imported.
First time it plays smoothly. If you let it loop couple of times, or even worse, stop animation, move time slider back and play from there, maya starts skipping frames, just like if you had a heavy scene which cannot be played back in real time. if i save the file and play again, it's smooth again. couple of playback loops - the same problem again.
there's no problem with sound itself, it's just that i can't get scene to keep up with the sound, which in lipsync situation is very big problem - i need realtime playback at all times.
i already tried turning off history, undo stack, different .wav bitrates... nothing helped. if i turn sound off, playback is fine, so it's definitely sound problem.
