I'm adding selected objects to a list using the ls -sl command, but when I return it I get "[u'objectname'] when I just want 'objectname'. Am I going about getting the name wrong or is there a way to record the names without the extra characters?
it would help if you printed your actual script, but:
string $sel[] = ls -sl;print $sel;
ls -sl
should print everything you have selected. If that doesn't work, can you give a little more info on what you have selected and the actual script you are using.
Error: Backend Fetch Failure
