ok here's my problem: obviously cloth in maya 6 has added quite a bit of accuracy/functionality, but i'm having a very basic problem with manipulating panels. For some reason, in m6 there is no construction history between panels and garments. The normal procedure/// draw curves , create panel, create garment....Now in Maya 5 i can group the curves and rotate/scale no problem the garment stays with it,,, but in 6 the panel rotates with the curves, but not the garment,,, I'm sure the curves are staying planar, because i tested in both with the exact same script, and it works in 5 but not 6. It seems like a basic problem of no construction history, but there is no option for construction history in cpPanel -newStitcher... any ideas? thanks
nick
